Hi All
I bought a Toyota Hilux (58086) about 15 years ago and being a young child when it broke, I never had the skills or the desire to bring it back to life. Roll on 15 years and I have just found it in my wardrobe and am ready to bring it back to life. The problem revolves around the power delivery, if I lift the car into the air the wheels will spin back and forth, but as soon as you put it down you can hear it whirring away but going nowhere. So I pulled the gearbox apart (with the help of a PDF guide on here) and found what I believe to be the culprit...the differential spur gear (or BG2) Some of the bearings appear to be missing and the outer bearing casing is scored, is this the source of my problems? How easy is it to get replacement parts? The diff housing and diff spacers e.t.c all seem in good condition Thanks |
Last edit: by v6matt.
Looks pretty shot. Can't theorize why the car wouldn't run at all though...
I've downloaded some manuals alraedy today so I can't look at the specifics right now. But if you check there what parts number it is and do a search on Ebay there will hopefully be a replacement available. |
Hi!
It's definitely the BG2 plastic gear that is your problem! The plastic piece you are holding should actually be a part of the plastic gear. Look at step 15 in the manual. The small metal balls should be in their own hole in the plastic gear. The way it is now, the spur gear will just spin on the outside of the balls and the wheels will be stationary under any load. There is as far as I can see two of these gear bags on ebay, look here and look here . I would definitely recommend Europro975 (the last link) over the other seller (CTY300) which I've had problems with -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
The following user(s) Liked this: v6matt
Yes, they are pricey, but also quite hard to find. There are many of models from Tamiya using these gears (Madcap, Saint Dragon, Astute, Monster Hilux, Nissan king Cab) hence they are popular and pricey
You can always look at the manuals in the Database -> Documentation -> Manuals section. It's only downloading PDF's that is restricted. -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Thanks - hadn't thought of that yet...
And when I take a better look at the pics I now see that indeed the whole inside broke off! No wonder it didn't want to run. No my sharpest day today! |
Agree with Edou definitely a restoration job even if you sell it on its a sought after model best
