| NiCd |
5 | 15.6% |
| NiMH |
13 | 40.6% |
| Lipo |
14 | 43.8% |
| Other |
No votes | 0% |
| Total number of voters: 32 ( Jack Willy Orz, cumminsdoc, Purple_rob, nivapilot, uncletom ) See more | |||
| Only registered users can participate to this poll | |||
2-ish month from this topic, I got the honour to say that I updated the old wall-wart into a quick Delta-Peak sensing charger (still a cheap deal, but scores more professional.) also, with an actual Ampere of power, charging a 2.000mAh batt, passed from 5-ish hours to a mere 2 hours. |
Last edit: by Dash_Crash.
wow this setup is fantastic. i tried a set of 35c rated batteries and.... omg so awesome! my buggy does powerwheelies now. ---- the nitecore d2 charger is amazing aswell. charges nimh nicad li-ion li-fe li-mn. with a full function display....... |
I am charging nimh and lipo battry's with my b6ac (geuine)
Last weekend it popped and stoppen. The power supply stopped. I made the charger open and i found a 4amp table adapter inside witch burned down. little low when a charger charges my lipo's always on 5amp's i guess?? There was a fuse inside the power supply but id did nothing! Now it's only the charger witouth power supply but i found an old pc onder a pile of hobby materials and i use the power supply from the pc! Now i got 12, 5 and 3volt to mess with! This is wat it's look like including my small conrad 2300nimh pack for my custom build mini crawler I am a little scared after seeing this last night in my hometown so i stay close to the charger to keep an eye on it www.dvhn.nl/dre...98316.html An empty case Now jump on the pc to check the image sizes (sorry if they are way to big i am working on it, just like my english)
Last edit: by poebe.
Thanks for your tip, Poe. I will charge it now. Perhaps I can use smell as an indicator? If it starts to fume I'll be quick to unplugg it from the outlet.
I've not yet started installing any radio system in my buggies, I've been busy building Fighting Buggy and then my Hornet. |
no! get yourself a better charger ! (smart charger)
(the charger of the vorklift was the cause of the fire) I build this fleet of rental boats for amsterdam and i know wat the do's and dont's are with battery's.. yes electric boats trust me you need a better charger mokumbootverhuu...elf-varen/ |
An advice I use for my lipo, Chaarge it outside. Like in your balcony.
