I watched some RC drifting with my 11 year old son last week and he said he'd like to try it (I would too).
What is a good, cheap chassis to get started on (emphasis on CHEAP, like <£30)? Bear in mind I have various motors, ESCs and radio gear lying about that I can use. |
A coworker has this, www.hobbyking.c..._KIT_.html.
It drifts pretty well and seems to be of reasonable quality. |
I didn t like the drift and found no interest but now i am fan. I have one of the cheapest drifter. Ak
F. _ standard tt01 with a set of used drift wheeles. Just a small advice, if you use it at home, the 540 is enough but in external, the chassis is underturning with standard motor 50€the tt01 20€ for a new drift wheeles set And I am the poorest pilot of the world Drifting is fun |
Last edit: by stingray-63.
The following user(s) Liked this: Martin Bell
Not had much luck with drifting myself, but not having anywhere local to practice doesn't help ...
attempt #1: "Drift Spec" TT01 chassis (Tamiya Sport Tuned Motor + oil shocks); added bearings, super hard tyres & RS200 body - wheels spun up ok, but either too well planted or underpowered meant understeerign rather than drifting attempt #2: TA03F chassis, same hard tyres, steering balljoints moved to inner position, also bearings & (different) oil shocks, Citroen Xsara body ... as power had been an issue before I fitted a 5.5T brushless combo. This didn't work that well, it was too well balanced & showed no inclination to get the tail out, just spin around its centre at high speed, with no chance of holding it - although I did manage one perfect drift (out of 100's of attempts) attempt #3: same car as #2, but with soft front suspension, hard rear, locked rear diff (to encourage the rear end to break away sooner), and dremelled front suspension components (to get more steering angle). Still haven't used 3+ years after those mods Cheapest chassis is going to have to be a TL01, I don't see why that couldn't work with lots of power & a few adjustments/mods
Yeah, finding somewhere to practice will be a challenge.
I'll keep my eye out on ebay for something suitable. I think I will find it easier to justify if I buy a wreck and do it up. Probably end up costing just as much, but will feel better to me. Annoyingly, I sold a TL-01 with a Merc bodyshell a little while ago. Would have been ideal |
So, I've bought this:
What mods will I need? Will probably be mostly using it outdoors (unless I can get into the local school hall |
TL-01, I think? Can't really go bad with that one.
Tyres depend on what you wanna do of course. Slicks for some carpet drifting or profile when outdoor rallying. Should be pretty easy to find some cheap ones in that common size. |
It's been a long time since I've fiddled with a TL01 chassis (and/or done any RC drifting ... or much RC driving at all, come to think of it) , however ...
Shell looks a bit rough in the photo so will probably be really bad when it arrives Bearings, 16 off 1150 IIRC Naughty motor, a Tamiya Sport Tuned won't cut it IMO, a 19T might. M3 studding & suitable rod ends (or similar) to replace the OE plastic beams to give it a bit of adjustability (e.g. a little toe out on the front?). Alloy hubs (12mm hex), preferably ones that can be screw tightened (black plastic OE are always breaking/falling off/loosing pins). Those tires light work ok (in the slidey sense) on painted concrete or parquet floors |
