need help with Mad Fighter 11 years 6 months ago #34267
Thinking of getting a replacement body shell just so I can spray it funky colours lok
need help with Mad Fighter 11 years 6 months ago #34268
Moved the topic to the Technical section and amended the title :)
-Lars
need help with Mad Fighter 11 years 6 months ago #34274
Thanks lars , also reamended the title
need help with Mad Fighter 11 years 6 months ago #34280
got me some pics now I am finally home unfortunately they to big to upload to the gallery on here and I have forgotten best way to make them smaller than 2mb unless people know of somewhere else I can store them and show on here
need help with Mad Fighter 11 years 6 months ago #34313
thanks for your help lars,
right here is the pics finally
front of car with different than normal tires (bro brought them me while I was away)
side view
new tires that I got from RC place near girlfriends.
yes I know the new back tires are stupidly big but I wanted to do something for a giggle, turns out I now have way to much grip on the back, after a full reverse and the forward I managed to flip it on the spot then later on I went round a corner and flipped it sideways.
on a different note finally got my bearings so off I go to put them on
need help with Mad Fighter 11 years 6 months ago #34322
well bearing finally put in but cant take it outside to test, dam rain :(
need help with Mad Fighter 11 years 6 months ago #34329
well got a new problem :( since I put ball bearings on one of the back wheels is spinning faster than the other and also the left wheel ( as u look from the back on the pic) keeps coming off of its own accord wile im using it. I have had the original wheels on and also had the gears apart and put back together countless times. only thing I have noticed is that one of the u shaped washers keeps going halfway up the wheel bar.
need help with Mad Fighter 11 years 6 months ago #34330
Check that you have the diff in the right way round.
Re the wheel coming off - you probably need new nylon wheel nuts.
Don't know what you mean about the UK shape brackets.
need help with Mad Fighter 11 years 6 months ago #34331
followed the manual so I couldn't go wrong putting it back together.
as for the wheel its coming off with new and old wheelnuts (that is if you are on about what actually holds the wheel on lol).
by u shape washer it looks like a washer but with a chunk missing from it and 3 bits that stick out on the inside of it
need help with Mad Fighter 11 years 6 months ago #34332
Is the u shaped washer a plastic piece about 30mm across that goes near the diff? If so, it should have 3 screws in it to hold it in place.
Time to create page: 0.280 seconds
