Found the Traxxas XL 10 new in box from the uk. As soon as it arrives and I hook it up I’ll let you guys know!
thanks and cheers!
The following user(s) Liked this: Girox
You'll want an ESC designed for brushless motors, as the 11T motor is likely brushless based on the description.
dino game |
Info from the Motor section of this site:
Motor description:This is a high performance motor designed for use with electric R/C touring cars. Equipped with 11 turn rotor, ball bearings, brush dampers and heat sink. Motor case with high power magnet efficiently dissipates motor heat. Timing adjustment, disassembly and maintenance is possible. Use with large capacity amplifier suitable for 11 turn motor. Tamiya C.P.R Unit cannot be used. Motor data Type: Brushed Timing: Adjustable Maintenance: Rebuildable Turns: 11x2 Normal voltage: 7,2 - 8,4 V Torque: 250 g/cm at best efficiency and 7,2V RPM: 38000 rpm at no load / 7,2V Brush orientation: Stand-up IG_tamiyaddiction
Thanks guys. Yes i know about the technical specs of the sp 11t and so as I was advised I got a traxxas xl10 esc. Still waiting to run it and plug it all in because I also bought a super Avante for the whole build around the engine and esc which I still have to start…
Will let you all know how it goes. Also I’ll try a 7.2 v battery then probably use an 8.4 thanks a lot everyone |
