So tonight I ran a test on the halves of an SRB gearbox
Last edit: by AndyAus.
When you say "glass media" do you mean glass beads or glass grit - it's kind of an important difference. And what size?
I'm using .5mm grit glass media If you can't fix it with a hammer, you've got an electrical problem mate
Thanks Andy - I think I can get reasonably close to those materials, though I might have to go a little finer to try & keep the cost down to sensible levels...
I'm impressed by the final result, it's the closest to factory finish I've seen so far - though it does look a little strangely brown - what colour was the glass grit? Recycled glass with a lot of brown in it? & what was the final scrub? Just water & somebody elses toothbrush? I'm a little disappointed there's no "magic" one media/pressure/nozzle size solution (so far), but changing the grit isn't that much hardship I guess - it's probably good practice to bag it up if it's not going to be used for a while anyway. I probably also need to do something to mouse proof the gauntlets too, come to think of it I think you should write up your process for Lars to put on the front page |
My media is just a little dirty and the lighting in the pic's made it look worse If you can't fix it with a hammer, you've got an electrical problem mate
