Kyosho hi rider 6 years 5 months ago #59513
Spend half day reassembling then disassembling it (550 motor appears seized but applying a battery it works...) So I swapped it for a 240s le mans it runs fine now... Had to re do too the steering linkage, now it goes true straight
The following user(s) Liked this: stingray-63, kwkride
Kyosho hi rider 6 years 5 months ago #59524
The car you got is actually a Hi Rider II, which apart of the bodyshell, has nothing to do with the original Kyosho Hi Rider.
The chassis of the Hi Rider II was taken from a buggy, and on dirt is faster than the original because of the lower weight and smaller tires. The Hi Rider has a heavier monster-truck chassis with large fat tires. I have the original and love it. Those chrome engines must really be one of the best things Kyosho ever did! :)
Kyosho hi rider 6 years 5 months ago #59525
HR2 new built and never ran. But with time the msc toasted. :(
Kyosho hi rider 6 years 5 months ago #59541
Today drove it on dirt, quite fun , but the unmitigated shitte I read about.... Isn't undrivable at all, if rear axle drifts all you have to do is a bit of countersteer...
Kyosho hi rider 6 years 5 months ago #59542
It was its first run. Congrats jaume.
Kyosho hi rider 6 years 5 months ago #59566
How I can remove the simulated engine (want to clean it) there's no screws so either is glued or double sided taped.
Btw gorgeous Finnish, the more I stare it the more I love it.
Kyosho hi rider 6 years 5 months ago #59567
Look into the manual. If it not screwed, it should be double side tapped
Kyosho hi rider 6 years 5 months ago #59568
If your car was built as per the manual, then the dummy engine is attached with double sided tape. Be careful not to break the body when forcing it. Why not use an old toothbrush with soap to clean it without removing it, then let dry?
Kyosho hi rider 6 years 5 months ago #59569
It has around 25 years of dust. It was exposed in my room. :D
Kyosho hi rider 6 years 5 months ago #59579
Want to fully disassemble it then paint it on more accurate colours (red on engine block with gloss silver on manifolds)
Time to create page: 0.238 seconds
