Re: Kyosho Raider Bodyshell 15 years 4 months ago #1501
will they fit the kyosho rim do you think or does it need to be a three piece rim? the rims on the kyosho are just a pull on fitment that you need to glue?
regards
Re: Kyosho Raider Bodyshell 15 years 4 months ago #1502
Could you maybe post a picture of the Kyosho rims?
There would need to be at least a groove in them - not a totally smooth surface.
I think you should be able to fit the Hornet tyres then.
Possibly put some inlays in the tyres - that way they would keep their shape better.
Maybe an approach like this could be helpful to get the glue to settle well :
Re: Kyosho Raider Bodyshell 15 years 4 months ago #1505
hi
yeah i have attached some images of the rims for reference. they are a little scratched up around the edges but only very lightly and as i intend to use this car as a light runner im not too fussed about it. the front wheels and tyres have cleaned up a treat and are re-mounted see attached pic.
regards
Last edit: by tamiya nut. Reason: pics
Re: Kyosho Raider Bodyshell 15 years 4 months ago #1506
Front wheels look very good. Nicely done. B)
Sadly the 3-piece Hornet rims I have here are glued together.
Wanted to see how big the inner flange on the tyre is exactly.
But in general I think it's worth a try. The tyres are easily available and not that expensive.
I'd give them a 'dry' run first - if the flange is too big you could cut off the tiniest bit.
Definitely think the rubber bands will be a helpful tool.
Sorry I can't be more certain - combining rims and tyres that are not officially matched is never an exact science. :dry:
Re: Kyosho Raider Bodyshell 15 years 4 months ago #1513
New decals arrived today from ebay seller and Tamiya club member tamiyoman. Thought you might like a pic have to say the quality of these is pin sharp im very impressed with them. I think ill send a lot more business his way in the future. All i need now is for teambluegroove to start selling again on ebay so i can get a bodyshell, apparently Canada post is on strike causing them to shut down completely.. :ohmy: Note the decals backing is clear just the card backing is white if that makes sense :unsure: ??
Regards
Time to create page: 0.118 seconds
