i think its called a Progress, if not can someone please correct me.
got this as part of a RC bundle. i put a battery in it and it runs, forwards and backwards manually moving the speed controller. it has acoms servos and receiver in it same as my tamiya's. what a nightmare to work on!!!!! i cant get the transmitter to work so i guess i need to find what chip is in the receiver but i cant work out how to get it out, there is about a million screws as far as i can see? |
ok so i have got it running now, using the transmitter.it goes forwards and backwards but the steering is back to front. right on the stick it goes left and vice versa.
is it possible to reverse the servo somehow. i cant change the linkages around as they wont fit???????? |
No, that's positive & negative ... well, actually it might do, I've never tried it. Downside is it might fry the servo and/or the receiver The "original Techniplus" transmitter as you put it - the AP227 mk. 3 - does have a crude servo reverse facility: undo the four screws holding the square grey bezel around the stick, turn 180 degress & refit the screws. The trim tab will be on the top rather than the bottom, but it's a mod at my favourite price - free
The following user(s) Liked this: agemax
NP BTW, the other transmitter you have in your "OMG" thread - an Acoms AP227 Mk.2 - also has a "servo reverse" facility if you need it - but it's even cruder: if you undo the screws that hold the back of the case on & remove the back, you can get at the undo the screws that hold the stick surround on. And yes, I am a bit of an Acoms anorak |
