I'm fan of your truck.
The other side turned out much better
Did the backside a bit different Also did mount the marker light with the small side out for easier soldering. Test mounted Was to fit tail light outermost hole, brakelight second and reverse on the inside. Will mount tail/brakelight in both outer ones and revers on inners. Bin turn signals as I hate them going every time you turning the wheel... |
Really cold🥶
Yeahh ! Awesome lights and like a real one. You should be able to take the road tomorrow with the volvo. 😉
The side marker lights on the bumper had stopped working for some reason. Seems the output from the led kit is dead.
New wire was made directly from the receiver so now they work again And yes I had to test it again outside. More snow has landed, so too much actually to plow anything but, tiretracks and downhill. Very hard to capture the side marker on photo This might be my favorite picture of the day Better real view of rear lights when brake lights is off Also make a short video... Now the rear lights is working it's time for black out the backside of the bumper and use Plasti Dip on the connections to minimize the light bleed. Not sure if I'm going to polish the bumper or paint it black to match the frame.. |
Been ME ill for a while now, but today I wanted to do some lights work again.
Time to make these roof marker lights I started a while ago, work. First I installed 3mm yellow led, soldered the wires, pained the mounting face for the glass chrome and glued on the glass. Made sure it work Made 3 so far today. Includinng paint them with a chrome pen Also very happy how the fender marker lights turned out I hope i will look good when mounted a lit up. |
