My Projects:
Few updates:
Just posted a thread on how to make your own LSD (limited slip diff): www.tamiyabase....id=78#8056 And the post man dropped off another part of my Pajero build: They are RC4WD Mud slingers, and I found them at a local hobby store of all places. They will most certainly help with the grip... My Projects:
Update:
Had a chance to do some work on the Pajero. Satrting with repairing the front of the chassis, where the "brick" was removed. (the "brick" is the front bulkhead of the chassis - called this by CC-01 owners because of it hitting anything you try to ride over.) Some of my goodies arrived today: A cheap rip off of the light control unit. Has brake, park flashing indicators, main beam, and reverse light. My Projects:
My Projects:
Just a quick speed calculation for the GRU:
7.4:1 Novak 55 turn speed = 8500 RPM output shaft speed = 1148.64 RPM Johnson 4 hole speed = 16000 RPM output shaft speed = 2162.4 RPM She's going to be slow. I might have to install the johnson 4 hole... Motor and GRU installed in the chassis: And all the other goodies: Bought this hollow aluminium tube for the grill: Hopefully I can get some primer on this thing tomorrow... My Projects:
My Projects:
Ok, I'll check tonight. I think you right
My Projects:
