Hi,
As my Avante restoration has stalled due to it being nearly done other than a hard to find body shell and somewhat pricey decals I went for something with a little more 'mileage' project wise. Other than the wheels, bumper and shell what's there looks in OK shape. There are parts missing though so this is my shopping list: Metal bearings Wheels and tyres Screw bag B (can't remember why) Screw bag D (to replace rusty screws) Body mounts Body, wing and decals. Tool Bag (for grease and those rubber sleeves that go over the rear shafts) 18T pinion motor esc battery I've already cleaned up the pastics so it's time to hit ebay. |
Hi Protean, is the chassis shared with the Subaru Brat?
Your build is looking good. <p>Current projects:</p>
what other models have you worked on?
Except for wheels, body mounts and on/off switch placement the frog and brat are the same. If I'm remembering right the original release of the brat came with plastic pogo sticks for rear shocks.
I definitively love the frog |
Why "Frog Re-Release rescue"? You could have more plausibly called it a re-re Brat, or an original Frog - what you have there is a "bitsa" - "bitsa" this, "bitsa" that
For instance - wheels (which are salvageable IMO) are definitely vintage - you can tell by the dilapidation & the slot head screws. Tyres are junk - but are vintage - you can tell by the deterioration & by the air holes in the rears. Body is original - you can tell by the real sponsor logos, especially the NGK one The bars across the top of the chassis are re-release, on the original it'd be a pressed aluminium plate to hold the MSC. I'd go as far as to say the chassis is in fact a re-release brat - you can tell by the plastic insert between the inboard front suspension pressed aluminium bits - that should have an alloy post on top. I just thought I'd mention it |
Because I don't know any better
Hmm all good to know thanks. I did think of buying a re-release kit but I'm definitely after a running Frog and project, it just seems more fun somehow, that and I wouldn't get to know any of this stuff otherwise! If I find any vintage parts online I'll be sure to get them. Good to now about the wheels too. I'll keep them and look into some kind of paint remover but if I get impatient then re-release wheels are quite available |
@Protean - If you are not using that Brat front body mount, I would be interested in it. The one on my sons Brat broke when I dropped it down the stairs
edit: Kamtec sell the Frog wing on its own quite cheaply - Click here. |
Last edit: by Martin Bell.
