The original 58050 Wild One came out in 1985, only one year after the 58046 Fast Attack Vehicle which uses the same chassis. This time instead of a military theme with a hard shell, they went with a sand rail style buggy using a polycarbonate shell. The drivetrain is mostly the same except for the replacement of the little plastic pogo stick shocks with aluminum oil dampers. The tires also went from realistic military tread to spikes in back and slots up front. The Wild One was re-released as set 58525 in 2012 and I was lucky enough to find one for a good price. It has very few changes from the original other than an improved shock assembly method and stronger axles.
This is a rear wheel drive, desert style buggy with a geared differential and four wheel independent suspension. The suspension is not double wishbone, instead all four corners have trailing arms. The shocks are nice oil filled aluminum units and the body, driver, and roof are polycarbonate. This is a very quick and stable vehicle that is a blast to drive. It isn't going to winning any races, but that was never the point. I did eventually put the mildly upgraded Torque Tuned motor into it for just a bit more speed. This is considered a classic buggy by most collectors and I can see why. With the addition of a scale engine in the back, it really looks like a real desert buggy. It is probably the last of the Tamiya buggies to look like any real scale vehicle. The Wild One comes in a big, colorful box with classic hand drawn art. Looking closely, I think I can even see the Ackerman correction on the steering angle! Too bad I can't make the driver turn his head like that. Inside the box the contents are carefully organized as shown. This is a pretty simple kit as you can see from the smallish number of parts. There are 3 numbered hardware bags. The main chassis tub consumes the bulk of the volume. The front suspension uses curved trailing arms. The arms connect to a steel axle which spans the front bumper as shown. This solution allows for a lot of vertical travel without the change in camber you would get from swing arms, and avoids the use of any ball joints. Harder to see is the black FRP plate which spans the support blocks beneath and stiffens the whole assembly to prevent cracking the chassis tub. The one piece bathtub is about as complex as any Tamiya bathtub chassis I've seen. It integrates the battery holder, an on-off switch slot, a receiver battery holder, slots for the steering rods, a bumper, and plenty of space for electronics all in one part. The right hand picture shows how the front suspension assembly attaches to the bottom with a handful of screws. The dual tall shock towers are bent aluminum plate. |
One of the biggest things that differentiates the Wild One from the Fast Attack Vehicle is the beautiful aluminum shocks. These have been modified from the original Wild One by replacing the internal floating piston and spring with a much simpler rubber bladder. The original shocks also had seals which were locked inside and not serviceable. The newer shocks have a threaded cap. These are very small diameter shocks which use some of the thinnest (red) Tamiya damper oil which is almost like water.
Now we'll start working on the rear suspension. The axles for the rear trailing arms are separate steel parts separated by the red spacer shown on the left. The little red side bumpers shown on the right protect the battery. You can see the horseshoe shaped slot for the wires. The shiny steel post will be the lock for the battery door. The cage is made from some fascinating plastic parts which have metal threaded studs molded right into them. Presumably these are placed into the mold before the plastic is injected. Once the molding supports are cut away the parts can be screwed to the chassis tub as shown. The cross bar is an aluminum tube.
The differential is a very simple gear unit with a thin ring gear and 3 spider gears sandwiched between the beveled outdrives. As usual, I added ball bearings to my build but not many are required for this model.
There is only one more gear in this simple transmission. It is supported by tiny 5x8mm bearings so you wouldn't want to put much power through this transmission. Once the other side of the housing is screwed on, there is a sheet metal support bracket which spans them and a little red cover which says "oil" on it. This is not really for lubricating the transmission since it is not a sealed unit. Here the gearbox has been attached to the chassis. The metal support bracket attaches to the lower rear cage, and the front of the gearbox attaches to the two vertical red brackets. Now I'll install the axles. The original Wild One used an axle with crowned hexes on the ends. The hex transmitted torque and the crowning allowed angular misalignment with suspension travel. The newer version uses simpler and stronger dogbones as shown. The original rubber boots are maintained to hide and protect the axles though. The trailing arms are retained with metal clamps as shown. You can see the "R" stamped on the retainer on the right hand side. Note how long the protruding stub shafts are. These go deep into the wheels and use a very thick hub. The hub does not use a 12mm hex. Instead it has holes which mate with protrusions on the wheels. |
The kit comes with both a 15T and 18T aluminum pinion. I chose the larger size for higher speed but replaced it with steel. You can see the gear mesh through the access port on the right. The mesh is not adjustable, instead there are two sets of holes, one for each pinion size.
The assembly of the rear shocks is pretty much like the front although they are shaped differently. Instead of the spring enclosing the entire shock body, it only covers the rod and bottoms on the cylinder. The rear shocks also use thicker yellow oil. They attach to the rear trailing arms and cage as shown. Now I can put the wheels and tires on and complete the rolling chassis. There is room up front for two servos: one to control the steering and one for an old mechanical speed controller. I only needed the steering servo which left me with plenty of extra space. The front wheels house bearings and rotate freely. The rear wheels attach to deep hubs which are specific to this vehicle type. The battery door is also unique and not shared with the Fast Attach Vehicle. The FAV uses a solid plastic door but the Wild One uses this skeletal FRP plate. The original car was designed to use a hump pack, but the newer version uses a standard stick pack. The polycarbonate body comes it three pieces: the main cover, the driver, and the roof. The cover is mostly a lid for the front of the tub but also wraps around the driver's station and locks to the B-pillars. The roof screws to the cross bars. The driver is really part of the body as well because he covers the middle of the chassis and the battery compartment for the receiver pack. If you are not using a receiver pack, this is just empty space. The body is just painted standard black and then decorated with stickers. Putting stickers on the rear aluminum dampers was not a great idea. I don't expect them to stay there long.
Years ago I bought a 3D printed engine for the Fast Attack Vehicle but then decided not to use it so I saved it for the Wild One instead. I thought it would look better with the style of the Wild One. The engine consists of two parts: a cap and an exhaust. The main part has air filters, a distributor, a coil, the top of a belt, and a single cylinder head. The exhaust includes a muffler. Both are printed in white as shown. I painted them with metallic paint and then did some detail work by hand.
In order to make this look like a complete engine, I also painted the plastic gearbox in aluminum. Once the 3D printed parts are attached, the completed assembly looks like a motor and transmission. These photos compare the rear of the model before and after the engine was installed. Before the gearbox is clearly plastic and not much detail is evident even though the red gear cover has some cooling fins on it. After painting and adding the engine parts, we get the photo on the right which looks really good. |
I love this dummy engine.
