Regards
Lee
Sounds likely for the name of the chassis...
Paint job was today for the body.
Started process by applying windows masks and then liquid mask yesterday early afternoon. Did apply black on the roll cage yesterday evenning. This morning, I started by removing the rest of the liquid mask. Objective was one single color for the body and wing, and some details being masked and painted under the body shell. (At the end, I can say, it would have been easier to work by zone with a two colors scheme, at least for the details). Applied the few mask for the details I wanted on the body shell: Then the next was applying orange fluo and white to back it. I then started to remove the masking for the black zones... While doing this, I noticed already the "Anytime Baby!" was probably too ambitious and decided to remove it completely and make the wing full fluorescent orange Then applied black, removed masks for red and applied red, and white and black for backing... Then some removal of masks again for the yellow part And finally, removal of the last part of the masking before white, silver and black to finish the inside of the body You may notice that the masking becomes extremely difficult to remove without damaging what is around due to the number of layers. Recuting this with a hobby knife may help. But it was too late to do it... Final result on the body: (I only show the good side - the details on the right side got broken partly due to the masking).. Next is driver figures (I will do 2 drivers, one for the Hornet, and one for my DT03)... I buy kits to built and ru(i)n them
I love the under shell decals.
Thanks. I maybe crazy doing this, but I like it: I've done them, using spray paint. That said, the result is not as good as I expected due to some issues wile removing the masks. But I really don't care. This buggy is mine, it is unperfect, and there won't be a second one just like this one. It's unique, and that what matters to me I buy kits to built and ru(i)n them
The result is very nice. And the method very interesting. Congrats.
Thanks... That being said, if I have to redo it, I would basically remove all white details and letters and apply white at the same time as backing the orange fluo. Then while the black while backing the white... then red details and then finally yellow. I was reluctant doing this as the white needs proper backing when applying non black color after it.
Anycase, it's my second body I do this way. I'm still refining the workflow... I buy kits to built and ru(i)n them
You've done a great job. It's an art form in itself painting backwards on Lexan. I never had the patience to paint like that back in the 80's, too much like hard work, I just whacked on some paint on to colour the body so I could go and race against my mates.
I will be attempting proper box art on my Lunchy, Hornet and on a 2nd Falcon body. I will attempt to remove and repaint the Quattro's, I will probably need some paint removal advice for those. If I can get a turbo optima pro body I will try a box art version of that too. I got minewith just a plain painted body. The duplicates and any other cars can have a simple paint job as they will be crashed at some point no doubt. I have a vinyl cutter and also cut a lot of masks by hand for my artwork. I use grey Oracle Oramask fairly often so cutting masks should be a fairly simple thing, I hope! I use glass to practice my airbrushing, pinstriping & signwriting, Have you considered using a pane of glass to practice on? You just paint the back of the glass instead of the front for body practice. Its a hard surface which matches the bodies and you just scrape the paint off with a flat blade when its dry and you can start again. Saves screwing up a good Lexan body when experimenting with designs or what colour works best. I know I will be adopting this technique before attempting any reverse painting. Lee Regards
Lee
