Ken's Grasshopper 15 years 2 months ago #2285
This is the (re-re) Grasshopper I promised to build in part payment for my Sand Rover :)
The first Tamiya I built was a Grasshopper, so this takes me back ...
Ignoring the manual, I started on the wheels & driver ...
Really bad matching of the parts though :(
So I'm going to cheat & swap with some from my spares box, after I've given them a bit of a tidy up ...
I'm donating a set of bearings (yes, there should be 9 1150's there) - I can't bear to build a car without them... 540 is a bad idea without suspension upgrades though ...
Had enough for the day ...
Re: Ken's Grasshopper 15 years 2 months ago #2291
Jonny,
You always need a Hooper to muck about with B)
Will this be staying boxart or will it be getting one of your great paint jobs?
GING
Re: Ken's Grasshopper 15 years 2 months ago #2300
Jonny,
GING
As I'm building it for a colleague it'll be strictly boxart ... although the driver's helmet is X-14 Sky Blue instead of X-4 Blue ;) ... white has to be my least favourite of all colours to paint :( ... anyway, there is a tiny bit of sunshine, so I'm off to get a bit of primer on before the GP qualifying :D
Re: Ken's Grasshopper 15 years 2 months ago #2302
Seems to be another "fast forward" build ;) ...
After giving the sink a good scrubbing, I washed & rubbed down the body with used 1200 grit paper; this is a "before" shot - note the heavy water beading:
.. and after keying:
This is after spraying Hycote white Plastic Primer ... doesn't really look that different :whistle: ...
... not even in close up ...
... this is it after rubbing the primer down (wet, with used 1200 grit paper):
... the deatil pic doesn't look that different, but it's visibly more smooth ...
Chassis is pretty much finished:
...as is the tyre lettering ... TBH I always struggle on tyres with smaller lettering like this, I think this is one of my better jobs:
Anyway, the weather is still holding, so I'm off to get some "colour" on it :silly:
Re: Ken's Grasshopper 15 years 2 months ago #2308
Gotta love the special attention you always give a paint job. B)
Re: Ken's Grasshopper 15 years 2 months ago #2311
I've come a long way - I didn't even paint my first Grasshopper back in 1984 :silly:
Re: Ken's Grasshopper 15 years 2 months ago #2312
I dont think anyone did, just to excited to get it blasting, even the decals where thrown on :woohoo:
GING
Re: Ken's Grasshopper 15 years 2 months ago #2330
Paint has turned out a bit disappointing ... it was nice & shiny when I left it yesterday & I was quite proud of it - any even shiny finish without runs - which is quite hard to do - the temptation with white is to spray _just one more puff_ ... and "faloop", you get a huge run .. but I didn't :(
Overnight though it turned a satin finish - which has happened pretty much every time I've used Humbrol "Hobby Spray" acrylic, so I don't think it's me, or the weather causing bloom ...
On to the decals - this set had been cut a long way out of register, so much so that I had to take between 0.5 and 2mm off one side off each piece before using them, or have awkward extra bits of clear to deal with . The decal sheet on my own re-re, and the spare set I have are much better ... I can only assume it was a Friday afternoon in QA when this kit went through :whistle:
After leaving the decals to dry & having smoothed them a few times, I thought I was safe to put the clearcoat on ... but about 5 minutes after I finished, the heavens opened ... it wasn't _quite_ a monsoon, but put it this way, 1:1 cars going past in the road outside were all leaving wakes ...
I haven't dared check how bad the bloom is yet ...
Edit - I removed the driver before clearcoating, painting the roll cage will happen after the clearcoat has hardened off & I can use liquid mask on it :)
edit edit - I should have used a bigger bowl -there's not "mushroom" in that one :silly:
Re: Ken's Grasshopper 15 years 2 months ago #2333
Funnily i have never owned a grasshopper? strange really as it such an affordable kit may put this on my shopping list soon. i enjoy the building process of my cars and this looks like such a quick build that i have not really considered it in the past. it seems to have so few parts. yours looks fantastic and has changed my opinion slightly.
Last edit: by tamiya nut.
Re: Ken's Grasshopper 15 years 2 months ago #2334
But you should try driving one - that'd change your opinion right back again :D
It's ok with the stock 380 motor in, but with a 540 motor, it's fun on smooth surfaces - not just tarmac, but sand, gravel & dirt - but show it some bumps & the shortcomings of the chassis become very apparent - ludicrous bump steer & pogoing rear end ... but it's the same for all of the "rolling rear axle" cars - the damping improves things a little on the Hornet/Super Hornet, the Pumpkin & Lunchbox get away with it because they're fun & they wheelie, as does the 1st gen Pajero ...
... but on the other hand, who buys a Tamiya RC for the handling? ;)
Time to create page: 0.174 seconds
