It's awesome Andy.
If Tamiya had put the re-hash Holiday Buggy (and Sand Rover) on the ORV chassis, they wouldn't have had to butcher the body moulds for the DT shock towers
The following user(s) Liked this: stingray-63, AJB
I'm really fan of the waffle tires.
Rainy day watching Motocross so figured I may as well build and fit the MIP ball diff to the Holiday Bush Brat, Once I started I realised my mistake. The rere srb gears that suit the diff are different to the OG
I've reached out to TTP
While I was checking my spares to see if I had gears, I found a Monster Beetle gearbox guard that will be going on
Attachments: |
Last edit: by 1972 LeMansGT Jim.
Hi all, Another update for the Holiday ORV. Needed to reattach the lower "A" pillars, a real week point for the body. Drilled a hole up the pillars and fitted a screw, a couple of holes drilled in the body and cable ties to secure the bolts. I have also finally completed the look with some OG wheels which needed a brake fluid bath on the fronts to remove paint from a PO but very happy 😁
Attachments: |
Last edit: by AndyAus.
