Yesterday I was ready to paint my 2 doors Mitsubishi Pajero Metaltop wide, 4 or 5 years after the start of the build
The car looks so small and cute compared to the 4 door version, which would become as big as a hilux (almost the same wheelbase) The great thing is that the cc-01 chassis can be streched easy because of the extra holes for the 58178: Honda CR-V Sport Utility, just an extra long driveshaft is needed. so the chassis doesnt need any customisation. The only thing you need is an extra Pajero shell, some 50 euro's a lot of time glue, putty and sandpaper. See here my photoshopped photo's from a internet pajero photo.
Only the rear area neer the gastank might become a problem, since the donor rear bumper isnt that big either.. Shall I do this? I mean there are already tons of normal 2 door pajero's. I would probably increase in value too since it is quite unique. Cheers, Feraz |
Last edit: by achmedachmed.
If you have the time and money I say go for it. It would be a very interesting build to see.
I'd like to see that
The following user(s) Liked this: achmedachmed
thanks for that link, I just read the whole 45 pages of an original build, seen some things I can improof.
How to use and cut the bodyparts is the most important part, i have found the best way to cut the 2 shells by staying away as much as possible from the detailed parts like doorhandles, doorlines, window lines etc. because you dont want to spend hours making a new door line if it isnt necessary in the first place. So the plan is to glue most parts togheter which are quite flat and easy to reach in the first place for easy sanding Should work like this, I will use the red-lined area's. Tommorow i will cut the first shell with cottonwire (my first time ever), and then I have to wait for the other to arrive.
These 2 should get me this
And hopefully this
I think I will leave the rearlights and front winkers as they are, just paint them instead of making clear ones .. I do need a longer driveshaft (maybe from a longer XC CC-01 model?) and some spare sidestaps to make longer ones. Cheers, Feraz |
It is a big but nice project |
Well now there is no way back, I am amased by this wire cutting technique. It is almost like a lasercut, the wire infacts melts/cuts through the body leaving almost no dust or plastic material. I still have to file the new edges a little bit.
Now it is time to wait for the second shell from Jason his store. Here a great video from a dutch guy who shows how to do this wire cutting Cheers, Feraz
You are a brave man, Feraz!
