My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20652
More progress on the Wheeler body - pics in order are:
- after clearcoat; nice and shiny ...
- ... but extreme closeup shows orange peel...
- sanded back with 2000 grit wet & dry ...
- polished with Novus 3 step plastic set...
- ... to make it properly shiny :)
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20658
well well well, another tp effort :) well done JR..
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20705
Still failing to put this one back in the cupboard :whistle: ...
Bumper & holder have been filled & rubbed down so are ready for primer/paint/clear - so it doesn't matter so much that I completely forgot about painting the roof spoiler :blush:
Tackled the badly/incorrectly painted lights with Tamiya X-20A Acyrlic Thinner & cotton buds (q-tips) ... they should have been clear oarange, clear red & nothing, but were pale pink, red & orange... the pink had badly etched the plastic :blink:
Painted body details & put a few of the home made decals on ... like the Pajero wheelie, I think this looks pretty good in plain white ...
... but I pressed on with the blue vinyl ... this is yet another car where Tamiya have the decal edges in boneheaded places - all the top pieces on the spats (wheelarch extensions) peel & look tatty very quickly, so I held them down with a bit of extra clear ...
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20706
Holding off on doing the other colour as I still haven't decided...
Red has to be 1st choice - it's boxart & anything else does hurt value (not that I'm likely to be selling this one on) ...
... although "official" alternatives won't hurt too bad, so I am entertaining yellow...
Sky Blue is beginning to look quite good too...
... but Park green , not so much. I've discounted the pink option, even if it is a dark pink/light red :whistle:
I've also painted the big M38 greeblies, old Willy figure was marked with a "V" on the back during painting so I can tell which is which.
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20710
There is so much nice work in this topic, that I don't know where to begin! :y:
Really good work, JR, I'm looking forward to the end result :woohoo:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20713
Gee those accessories came up nice to JR :) great attention to detail :y: especially the jerry can .
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20715
Thanks chaps - I think it's working out quite well, though not that quickly - if I hadn't kidded myself that I was just going to check what bits it needed then put it away, I might have gone about it more methodically...
Anyway, although the helmets worked put quite well, I really wanted to do a bit more testing before committing myself to yellow, so fiddled with the boxart pic ... I cn't do anything with the red windscreen strip surrounds, but I think that came out nicely..
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20717
Polished some chassis bits - round aluminium bits I spun up in a drill with 400 grit wet & dry then with autosol, chassis tub & mechanism box were done with Novus plastic polishes (which are lasting pretty well, despite the tiny 2oz size) with a bit of work with wet & dry on the worst bits:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20719
Due to the number of fasteners missing, chewed up or destroyed in disassembly, I'm going to rebuild with (mostly) stainless fasteners ... the list is pretty much as per the Wild Willy:
Screw Bag "A":
a2 (4mmx8 round head screw) - replace with 9 off M4x8mm cap head machine screws
a3 (5mm grub screw) - replace with 4 off M5x5mm grub screws
a4 (4mm washer) replace with 4 off M4 washers
a6 (4mm spring washer) - replace with 4 off M4 spring washers
a7 (3mm spring washer) - replace with 4 off M3 spring washers
Screw Bag "B":
b2 (3mmx8 aluminium countersunk) - replace with 2 off M3x8mm countersunk screws
b3 (3mmx15 round head) - replace with 3 off M3x15mm cap head machine screws
b4 (3mmx4 round head) - replace with 2 off M3x4mm button head screws
b6 (3mm grub screw) - replace with 2 off M3x3mm grub screws
b7 (3mm washer) - replace with 4 off M3 plain washers
Screw Bag "C":
c1 (2x15mm round head screw) - replace with 1 off M2x15mm cap head screws
c2 (2mmx10 round head screw) - replace with 5 off M2x10mm button head screws and 6 off M2x10 cap head screws
c3 (2mmx6 round head screw) - replace with 14 off M2x6mm button head screws and 2 off M2x6mm cap head screws
c4 (4mm self tapper for front wheels) - use original self tappers or replace with 2 off M4x8mm cap head screws
c5 (4mm flanged nut) - replace with 4 off M4 flange nuts
c6 (3mm flanged nut) - replace with 7 off M3 flange nuts
Screw Bag "D":
d1 (3mmx10 round head screw) - replace with 7 off M3x10 cap head screws and 10 off M3x10 button head screws
d2 (3mmx6 round head screw) - replace with 16 off M3x6 button head screws and 7 off M3x6mm cap head screws
d3 (3mm nut) - replace with 8 off M3 full nuts and retain 1/2 height nut from helmet
d4 (2mm washer) - replace with 2 off M2 plain washers
d5 (2mm nut) - replace with 10 off M2 full nuts
Other bits:
e1 (2mm roll pin) - replace with 2 off 2mmx12mm roll pins
n8 (3mmx60 countersunk screw) - these are impossible to replace, so retain originals where possible. 1 is used in motor pod & _must_ be countersunk, other 2 are used as rear suspension struts & could be replaced with anything the right size & long enough - but the best I've found so far are M3x60mm cheese head BZP screws :(
n9 (4mmx70 round head screw) - these hold the front end tubes together, they are generally fine but can be replaced with 3 off M4x70mm cap head machine screws
You may also need fittings for the rx switch, typically 2 off M2x10 cap head screws, 2 off M2 plain washers, and 2 off M2 full nuts
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 13 years 6 months ago #20720
:y: thanks for the list was working on that myself.
Time to create page: 0.195 seconds
