I hope that it will have a long thin antenna with a triangular flag
I do have a spring base Tamiya antenna whip somewhere 🤔 Nice idea Flo
The following user(s) Liked this: stingray-63, GToddC5
Decided to make a shifter for this, Used the same rod as the steering shaft and thread one end to M4 and tapped the other to M3. Machined an old alloy pinion for the base and tapped to M4, Machined the hex off an M3 ball stud then bent the rod to the angles bringing it close to the driver. I used real world principals where driver doesn't have to move his hand far from the wheel to reach the gear shift 😁
Attachments: |
