The marui doesn't be positioned on the top. from remind. side bars are moulded. |
Last edit: by yogi-bear. Reason: missed a file
Top work yogi
cheers Jonny. Bullfrog, I cut the chassis in 2 mm polystyrene sheet as its cuts like butter on my cheap cnc machine, once I've got the design right I'll cnc it in aluminium, happy to share plans as well. I also intend on machining the axles about 1 mm so I can insert ball bearings as I want this one to be a runner.
bearings are: 4 mm thick, 11 mm outside, 7 mm inside. I based the idea of machining the axles to 5 mm on this mod I found:
bigbear.mirage-...com/Axles/ cheers Johann |
