Just found out that I can use normal CD's that's how I like it, fast and cheap
Also got in eBay 5 O-rings of 11 Cm (god, I hope they can stretch to 12 Cm a CD has) I already have wheels sorted *yay*
The following user(s) Liked this: BCM06
Last edit: by Dash_Crash.
Did remember that for this to work I should replicate original 1902 build methods, found that wheels in the baker were spoked wood rims encased in sheet metal so I have to mount a wooden spoke wheel over a cd and make the outer rim with a very thin stripe of wood (where I could glue the tire. Oh, also I got impatient and completed the frame chassis with screws, oh my it's going to be a car...
Some data Scale of 1/8 dictated by the cd size, rear axle of an f104, suspension in rear axle with no dampers (those weren't in style back then) no differential too, reverse operates a mechanical brake And also a circuit to isolate the motor, so, no reverse fiber glass body, expected top speed 25+km/h weight 2.74 kg... |
Awesome can't wait to see this. Will you use balsa and Dowling for the wheels. Perhaps you could steam balsa around the CD and clamp it... keep us posted.
