Magnetic body posts 10 years 1 month ago #40411
Hi
What's the best glue to use to stick the magnets
To the underside of a lexan body
Neil
Magnetic body posts 10 years 1 month ago #40412
I use double side tape for carpet. :lol:
Magnetic body posts 10 years 1 month ago #40629
Well the double sided tape doesn't work
Magnetic body posts 10 years 1 month ago #40630
Maybe hot glue, it's kinda messy though.
Magnetic body posts 10 years 1 month ago #40645
In what way "didn't" work? Fail to stick?, pull the paint off?, something else?
Magnetic body posts 10 years 1 month ago #40646
... and not a good idea due Lexan being a thermoplastic, and hot glue being, you know, hot? ;)
Magnetic body posts 10 years 1 month ago #40655
Hmm... I recall someone having fixed the F40 shell I have with the stuff.
Must be another substance then. Haven't ever used it myself actually.
:whistle:
Not an option to put it on the magnets, let it cool a bit and then apply? How hot is it practically...
As Lexan® and Ultem® are isotropic and amorphous polymers, they are relative dimensionally stable at high temperatures. Short-timed tests (30 min) in the laboratory did not show noticeable changes of measurement. Lexan® was tested up to 135°C and Ultem® up to 150°C. Lexan® films with a thickness of 0.075 up to 0.125mm shrink about 0.5% at 150°C (glass temperature). Thicker qualities shrink about 1% to 2% at the same temperature. At temperatures above 150°C the shrinking increases clearly.
www.mueller-ahl...-of-lexan/
Magnetic body posts 10 years 1 month ago #40657
:whistle:
No idea about other makes/models, but there's a warning label on mine (a 2003 Arrow Electro-matic TR550) says the glue & nozzle reach 196 Celcius.
Magnetic body posts 10 years 1 month ago #40658
They apparently come in high (170-195) and low (75-130) temperature versions...
www.fpvforme.co...ns-better/
www.gluegunsdir...-low-melt/
It probably wasn't the greatest general recommendation though.
Re:Magnetic body posts 10 years 1 month ago #40659
I used hot glue on several lexan shells to install lights and to keep the wires in place no problems so far.
Time to create page: 0.248 seconds
