The M3 is a pretty good machine, I have one and I find it quite reliable. It can get a little smelly though with the washing station and even some resins so be careful there. I am using ethanol as my cleaning solution though which does smell more than IPA. I also ended up putting my resin printer and wash station on a decent height garage work bench to make it easier access etc.
Looking forward to seeing how you set things up and your test results!
IPA smelts like the beer? ššš¼
I've looked at the different way to wash the parts... Some uses Ethanol as it is cheaper than IPA. That being said, IPA has a key advantage : you can recycle it easily by exposing the bath in a closed box to sun for a day, and filter it, and you can reuse it. It appears it's not as easy for ethanol from what I read here and there...
For the test, I think I need to learn first I buy kits to built and ru(i)n them
The ethanol is quite dangerous to, vapors are flamable. I don't know what is IPA.Ā
Well, that thing is crazy...
About 15 minutes to get everything ready, about 10 for a firmware upgrade or less, I was not next to it... A print, 7 minutes of calibration to start it... (if you want to see the hot end moving : imgur.com/pO9Zlci ) And 17 minutes later... And some detail pictures And the quality is just impressive... I'm printing right now a bed scrapper... And that was less than one hour after it was unboxed... It took about 48 hours to get a decent print on my Ender 5 plus. It is really impressive... I buy kits to built and ru(i)n them
Well, It's a bit noisy during the calibration steps, I'm using it at normal speed (it was not even Sport or Ludicrous mode), but I don't find it that noisy : my Ender 5 Plus out of the box was doing much more noise until I put the silent board...
That being said, I'll measure with a DB Meter... I buy kits to built and ru(i)n them
thatās good, some of the reviews i watched seemed to think it was noisy, but it looks as if those issues have been addressed.
On a side note I have started to model the Hunter body, so Iāll see how that goes. On a work related project, Ā come across a Phrozen resin that is high temp and quite rigid and durable, so once the Hunter model is designed, I am going to try resin printing it in sections and then vac forming it. It should be quite suitable for vac forming repeatedly.
