The best spur for 12mm drive hexes? 13 years 11 months ago #15679
  • Stevepi
  • Stevepi's Avatar Topic Author
  • No Guts No Glory!
  • No Guts No Glory!
:unsure:
Hi folks
I am restoring an older model Tamiya with the 12mm drive hexes, I had a small tray with lots of these in it, but I recently ran out
Does anyone know of a small sprue where I can get 4 hex's without buying lots of other parts, I don't need for more money, I don't want to spend :-) yes I am tight! LOL. The price of Tamiya parts seems to be on the up and so with it the cost of restorations...
I remember when.... :-)
Regards
Steve
Re: The best spur for 12mm drive hexes? 13 years 11 months ago #15684
Do they have to be Tamiya ones?
Plenty of other makes use 12mm hexes - Traxxas for instance. Look on ebay for those.
Edit: My mistake - I think Traxxas hexes might be 14mm :blush:
Last edit: by Martin Bell.
Re: The best spur for 12mm drive hexes? 13 years 11 months ago #15687
I got a handfull of plastic ones lying around, (even a original set of TF evo hexes :P, not much different than the rest though )
as I mostly replace them with GPM or Tamiya aluminium hexes.
but maybe somebody UK based has some leftovers too, might be easier on shipment.
If you want to buy new and need at least 4 than I think the cheapest are the Tamiya - 53056 aluminium hexes (4x)
Re: The best spur for 12mm drive hexes? 13 years 11 months ago #15692
I'd go with alloy hexes too. Are they regular ones or possibly longer? What car are they intended for?
I like the black alloy hexes with grub screw. Like the GPMs or the Axial narrows.
Then you won't lose any axle pins when you take of the wheels.
Just don't get the ones from Racing Punk. They are something that will show "badword" if I type it...
:whistle:
Re: The best spur for 12mm drive hexes? 13 years 11 months ago #15732
Annsmann do a "small pack" of 4x plastic 12mm hexes + 4x drive pins + 4x wheelnuts, that definately fit Tamiya models - just had some for the Thunder Dragon resto I did. They were about 3 quid, from BlacksmithProducts I think (Check Ebay, "12mm hex adaptors" & list by "Buy now" "Price + P+P cheapest first")
Time to create page: 0.146 seconds
