holiday buggy gear set 15 years 3 months ago #1686
Hi all my name is colin. I have a vintage holiday buggy which is in very good shape apart from one of the gears which has been stripped. I am looking to buy a set of gears. can anybody help with a set or can you suggest any alternative grars that might fit
Regards Colin.
Re: holiday buggy gear set 15 years 3 months ago #1690
Regards Colin.
Gears regularly come up on ebay ... but not at realistic prices if you ask me - I have a car in the same state :(
Depending on which gear has stripped, and what motor is in the car it might be possible to upgrade & not use the gear to get round the problem - 380 motor equipped cars use all three gears - the "A" gear (next to the pinion), "B" gear (idler) and "C" gear (spool - what would be the diff, if it had one), 540 motor'd cars just use the "A" & "C" gears, but with a different motor bracket... so if you car has a 380 motor in it, and it's the "B" gear that has stripped, upgrading to a 540 motor could be a "fix", assuming you have/can get the larger motor plate.
As to what other gears might fit, I had it on good authority that the "spool" gear in SRBs (Sand Scorcher, Rough Rider, etc) was the same - but from looking at the manuals, it isn't - it's a lot wider for a start, and the SRB gearbox is quite a different setup - the motor pinion meshes with a large "drive" gear which has a much smaller gear on the other end of the shaft, this meshes with a small idler, then on to the spool ... so I can't see that fitting without major work - it's be quicker to graft on a whole SRB gearbox I think ... and if you're going to do that, you might as well use the SRB chassis too ;)
No real answer from me then - but if you come up with a viable replacement setup, please let me know! :)
Time to create page: 0.313 seconds
