Silly question 13 years 5 months ago #21628
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
Which hole to use for the motor mount - and what's the difference? :whistle:
No mention of it in the leaflet. Only that the motor is 0 degree timing.
I just chose the one on the right...
Silly question 13 years 5 months ago #21633
Normally you have to use the counterpart hole. It doesn't matter which one you're using.
I'm lucky that my motor has 2 holes 'cause as you can see on my honda nsx thread, i had a hard problem, mounting the motor because of the small 16T Pinion gear. It's now mounted with first hole from left above and first hole from the left at the bottom - not the counterpart.
It's working and drivin. But hey, the maingear of ta05 is loud!
Silly question 13 years 5 months ago #21635
You would use the two across from each other.
Silly question 13 years 5 months ago #21637
  • Edou
  • Hopping Mad
  • Hopping Mad
Thanks for the feedback. Yes, I've used a pair that matched opposite-wise. :y:
Be it the other ones from those marked above...
I was just wondering if there's any effective difference. :huh:
Seemed to be convenient on funkindemup's TA05 altough I don't think that's the official explanation. ;)
If it doesn't matter, then why not make one hole? :whistle:
Silly question 13 years 5 months ago #21638
They are there to give you more options for the pinion size's when working in conjunction with the gear box mountings :)
Silly question 13 years 5 months ago #21640
  • Edou
  • Hopping Mad
  • Hopping Mad
I was just visualising how it could have a slight effect on how close the pinion hits the spur.
Think I chose the "tight" option...
Edit - or maybe not. :lol:
Silly question 13 years 5 months ago #21644
the left holes are for positioning the motor on the gear box plate and the right ones for tightening it in place. B)
:whistle:
:laugh: :laugh:
Silly question 13 years 5 months ago #21645
now that was one silly answer. :silly:
Silly question 13 years 5 months ago #21646
  • Edou
  • Hopping Mad
  • Hopping Mad
That deserves a thank you as well. :silly:
I think I figured it out though...
Silly question 13 years 5 months ago #21788
I think it's to calibrate this a little bit 'cause of cable connections (or decal of motor ;)). Maybe there are motor mounts with 4 holes?
I've got the next silly question: If the gear ratio is the same, is there any different using a huge or small pinion gear? For eg on ta01 you can setup 8:1 ratio with a 20T/66T or 21T/69T or 22T/74T.
IS the smaller pinion better for motor on an offroad track?
Time to create page: 0.313 seconds
