Sand Rover - 380 motor pinion shim 12 years 6 months ago #28212
  • dreadly
  • dreadly's Avatar Topic Author
  • Born to be Wild
  • Born to be Wild
Does anybody know where I can get or do they have a shim for a 380 motor ? - I tried to get a new pinion to fit but the pinion is around 3mm and the motor shaft is around 1.5mm or so.
Not sure what to use.
Prepared to pay inc. postage if anybody has anything suitable...
Sand Rover - 380 motor pinion shim 12 years 6 months ago #28213
Hi Dreadly
I had the same matter with my holiday buggy. But here is no matter. In reality, the pinion is standard. You have a small. Brass tube between the motor and the pinion.;-)
The following user(s) Liked this: dreadly
Sand Rover - 380 motor pinion shim 12 years 6 months ago #28217
  • dreadly
  • Born to be Wild
  • Born to be Wild
Hi Dreadly
Ahh, ok, so I just need some brass tubing? - Any idea of the size?
Sand Rover - 380 motor pinion shim 12 years 6 months ago #28218
I would say inner approx. diam 1.5 and outer 3mm :)
Sand Rover - 380 motor pinion shim 12 years 6 months ago #28219
  • dreadly
  • Born to be Wild
  • Born to be Wild
Thanks, have ordered some... We will see :laugh:
Sand Rover - 380 motor pinion shim 12 years 5 months ago #28929
540 motor shafts are actually 1/8" (3.18mm) diameter, not 3mm & that extra 0.18mm will be needed to prevent a sloppy fit.
1/8" outside diameter brass tubing is common & easily sourced, what will cause you problems will be getting the inside diameter right to fit on the 380 shaft - you could either get thick-walled tube & drill it out, OR get thin-walled tube & "Tin" the bore with solder to make it slightly smaller.
If you get really stuck, I have the technology to manufacture a proper bush that's the right size, but I might need an accurate dimension for the diameter of your 380 shaft (I don't think I own one to measure myself...) - PM me if you want to investigate this route
Sand Rover - 380 motor pinion shim 12 years 5 months ago #28934
Isn't it this one?
www.modellbau-s...st=9804535
Sand Rover - 380 motor pinion shim 12 years 5 months ago #28936
I think it is...
Sand Rover - 380 motor pinion shim 12 years 4 months ago #29224
Hehe, just been checking my signature links to make sure they all work (1 didn't) & stumbled across a dimensioned drawing of the pinion bush/sleeve thingy that I'd forgotton I'd don, & made, & fitted...
Click on the "Holiday buggy motor bracket drawing" link at the bottom of my posts & you should find the bush drawing in there, amongst a variety of other really exciting Holiday buggy bits drawings.
Enjoy!
Time to create page: 0.115 seconds
