Spent two hours on Friday soldering wires onto and testing various motors out of my spares box and managed to find a 27T motor that seems to run OK. Need something faster for my TRX-3 though.
I now seem to have a big pile of motors all with various faults. I will rig up some proper testing gear at some point and do some more methodical testing. I've got a big pile of MSCs I can use. I am most dissapointed about the Kyosho Superstock 34 motor out of my Meteor. This looks like it is in really good condition, but gets very hot very quickly when run. In particular the brushes seem to get really hot. Here's a list of what I have - can anyone tell me anything about them: Team Orion "Havok" 23T Trinity "Monster Horsepower, 1987 World Champions" (says STK on the can) Kyosho "Super Stock 34" LRP V10 Spec. 3 15x4 Yokomo "Psycho" MG Model Products "Buggy Special, Brown Dot" 27T 22AWG |
When it's run in the meteor, or when you run it at all? If the former, I'm thinking a gearing issue, how many teeth has the pinion got? |
No, when I run it on the bench with no load. The Meteor has never run in my possession - another unfinished project
Has the Kyosho Superstock got adjustable brush timing? - sounds like it might be over advanced (If you can rotate the endbell, try turning it say 3 degrees in the opposite direction to normal forward spindle rotation). In fact, good point, I take it "Normal" forward rotation of that motor is right for that car & someone hasn't adjusted the brush timing to make it "tuned for reverse direction"?
Look on the front of the Trinity Monster Horsepower - has it got "Epic" stamped on it? If so, these motors are usually pretty powerful, normally 27T but behave like a 17x2, drain batteries quickly & are prone to comm & bearing wear
