Here's one for the crawler truck tech heads. I'm building a TLT-1 and was hoping to find some rear axle steering lock outs as I'm not keen on having 'steering' on the rear that not functional. Two questions, well two and a bit actually.
Qestion 1. I read that the F350 rear axle fits the TLT-1 but it looks different in the pictures I've found. So does it? Question 2. If it doesn't is it possible to work the front and rear steering servo's + the F/R control using a 2 channel trans/rec? Question 2.5. How? I'm not overly keen on the way they just lock the steering by screwing the drag link to the axle housing, it just looks dodgy. |
I know that the F350 use some juggernaut and TLT stuffs and on mine, I put the twin steering mode on a single servo.
You use a "servo y splitter cable" to connect two servos to one channel on the reciever
Unfortunately I am not familiar with F350 High Lift, but the TLT-1 can be modified to accept any axle unit I am sure! The only TLT-1 axle lockouts I know of were RC4WD.com Straight Axle Adapter for Tamiya TLT-1 . Unfortunately they are discontinued. They require some chopping/filing on the axle. That's why I never got those and stuck with 2 steering links attached to the axle housing |
For the HI LIFT, all is included in the box to make it 4X4X4 it is approximatively the same system than the clod but prettier than the full black plastic.
I did read in the instructions about the Y joiner but it didn't mention a tamiya part number. It also mentioned a 3 channel with mixer. As I don't have a 3 channel set up and the wife won't let me use her Kenwood, it was back to using the 2 channel idea. This raised another problem, a Tamiya design one. It shows the rear steering servo fitted with saver pointing up and a silly great tall tie rod end ball fitted. This looks like a really bad after thought and hits on frame on full 'twist'. I did find a 'reverse' Y section mentioned on a crawler site but can't find any for sale anywhere. Do these have to be custom made? Can't the wires on the servos just be spliced together to acheive this?
# I searched for "servo reverser" on eBay & there were any number of suitable matches - though admittedly the reversing Y leads I looked at reversed the signal on both outputs. Presumably if you want to split the steering signal but reverse one output you'd get a regular Y-lead and a separate reverser to use on the relevant leg. |
Hmmm, I might be mistaken. The servo reversers on ebay have some electronics in them. I suppose just swapping the input wires will reverse the motor direction but will also reverse the polarity of the position pot, so they will cancel each other out. |
Last edit: by Martin Bell.
I found a ternigy reverser cable at hobby king, I'll get a couple and 2 y leads as well, they're pretty cheap so 1 of each for spares. I assume the reverser goes on the rear steering. Please excuse my lack of knowledge in the electronics department, I can rebiuld an e type jag with my eyes shut but electronics loose me completely.
No problem nodtec I'm like you. (not for the e type but with cars diagnosis)
