Just got a cheap Viper chassis & I have the TBLE-02 ESC.
I really want to make a budget brushless basher... any advice on which motors i can use in it? Also, any other steps needed, or just pop it in, set up ESC & go? |
This ESC is especially designed for use with the TBLM series of Tamiya Brushless Motors (Sensored-Type, 10.5T, 12.5T, 14.5T, 16.5T).
nb: Quoted from Tamiya USA web site If you can't fix it with a hammer, you've got an electrical problem mate
stick to brushed, cheaper and easier to make your setup waterproof.
get a steel pinion and if not already done ballbearings. dont get the balldiff the geardiff is way more robust for the DT series |
It doesn't matter with brushless, but I would connect B to yellow and the blue and orange to either of the remaining a and c order that gives you forward motion. If you can't fix it with a hammer, you've got an electrical problem mate
OK - Back for more help! I have got it all set up, soldered & plugged in, but it's not working well. The motor just judders a bit & stops & starts. On the below video, the throttle is on all the time.
I tested the solders by running a wire straight from the ESC to the pin on the motor & it's the same... I also tested it on another TBLE02S (switched to brushless) and it was the same. Can anyone help? |
What you're doing there is "free revving", it's been received internet wisdom right from the birth of brushless technology that to that to a (brushless) motor will kill it.
I've never really looked into the veracity of that (but on the other hand I've remembered it & never tested a motor like that); two minutes Googling came up with a catalogue of failures, scans from manuals, etc etc. |
Hi - I'll take that on board & not run it without load. But any ideas on the fault? The stop/start in the vid is not me, the transmitter throttle is on all the time. The magnet is fine, i just had the can apart & can't see any damage.
Last edit: by wigtype.
Could still be damage to the sensors from what I've read ... I think there are some more things to try though: try the motor in the car in case there's something clever shutting the motor off to prevent it overrevving while being run without load; does the TBLE02S have BEC? if not, does your RX? Test everything else in the system by substitution (battery, RX, TX, crystals if appropriate, maybe even the servo); Is it RF interference? |
Someone I know successfully used the
TBLE02S ESC with a non Tamiya 10.5T BL motor
Makes quite a cheap setup I think. |
Last edit: by Martin Bell.
