TA03 Ball differential won't stay tight 11 years 3 months ago #34878
So... I've restored my old TA03R, double deck CRF chassis, hi-cap dampers, one way diff up front, brushless system & digital radio and ball differentials in place of the old gear diff's. Problem is that after a few minutes running the differentials loosen up and suddenly I have very little drive.
Anyone have any tricks to keeping the things tight enough to work but loose enough to work? (Wrap your head around that one!)
TA03 Ball differential won't stay tight 11 years 3 months ago #34879
That's tthe matter of the brushless. Put the gear diff you will not have this problem. too much power withthe bl
TA03 Ball differential won't stay tight 11 years 3 months ago #34882
same problem with my avante running a brushless. Tamiya issued a notice with the 2011 build manual as a separate page stating that thread lock should be used and I neglected to do this at the time. Seems to have done the trick
TA03 Ball differential won't stay tight 11 years 3 months ago #34884
ball diff work like a slipper and they are not made to support the brushless power. I had the same problem with my trx slash slipper. I had to block it. Now it is allright. I just rounded1 hexa adaptor :huh: :lol:
Time to create page: 0.115 seconds
