No clue
I am looking for 1 front wheele (rim+tyre) used to build a runner with my spares. If anybody has one, I am interested. Thanks |
Hi Flo, I’m in the same predicament of having to paint a Holiday Buggy shell.
The thing is they were never intended to be painted. So I think you will need a paint that can flex a bit. Especially if you plan to run it. I think I can help on the front wheel and tyre. I’ll dig some out and see if they are good enough.
Yes it's PE (polyethylene). I've had reasonable results (for the shelf, and very light runs around the garden) by scuffing up the body to an even old jeans sort of finish, then using acrylic auto paints. Using adhesion promoter first would probably give a slightly more secure finish. However - your HB body looks to be in very good order, so I'd be tempted to see if you could remove the last of the existing paint, sand any damage with increasing fine grades of wet & dry paper, then polish back to a factory moulded shine?
Thank you Jonny. I hope to have a small result because of already glued parts and several run damages. I will see if I can save it.
