water decals interrogation 9 years 10 months ago #41830
:unsure: My wife offered me a nice static model. But stickers are water decals and are very fragiles. Can I spray a clear coat on the body after a good drying? They are "modern" Tamiya decals but I am afraid by the wrinkles risks.
Anyone can help me?
Thanks
Flo
water decals interrogation 9 years 10 months ago #41839
I've seen people clear coat over waterslide decals, but make sure to test if the clear reacts with the decals first.
Have a look at this video:
water decals interrogation 9 years 10 months ago #41840
:y: Thank you Lars
water decals interrogation 9 years 10 months ago #41843
I've used Humbrol "DecalFix" on waterslide transfers - the instructions say to soak the transfer in the fluid and apply some to the model (i.e. use in place of water) but in my experience that's far too much & will destroy the transfer.
Instead, use water to apply the transfer & let dry as normal, then if there are any parts of the transfer not conforming to details underneath (panel lines, hinges, rivet details etc etc), then apply a tiny bit of DecalFix to that area only.
That part of the transfer will wrinkle/swell up, but once it dries overnight, it will shrink back around the details :)
Re clearcoating - what Lars said, but I'd also suggest airbrushing rather than an aerosol - X-22 Clear, X-35 Semi Gloss Clear or XF-86 Flat Clear depending on the finish you want. Obviously use the lowest pressure & thinner dilution rate you can get away with - it should behave (mostly) like X & XF paints :)
water decals interrogation 9 years 10 months ago #41845
:y: thank you Jonny. I will try that.
Time to create page: 0.250 seconds
