Reminds me of a certain Vintage re-re Frog i have the pleasure of owning , tho that has been rectified now |
Great debate, going on
Just to be clear, I'm not refusing the points I mentioned earlier, I just wan to see some kind of proof and evaluate based on that. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
Jonny, here is my topic on my SRBs. tamiyabase.com/...mitstart=0 I am really proud of them. Same if the ranger is a replica and the super champ a rere body. I think that it could be interzsting to have coherent chassis and not a mix if I could have a real mk1 or a complete mk2. Thank you for your advices. |
Last edit: by stingray-63.
I had a look through & it seems to me that the vintage parts are on the "correct" chassis & there's nothing to be gained by swapping parts between the two
Thank you Jonny.
That's crazy! It is like if tamiya made prototypes all along the lifz of first SRBs.
Like Harley Davidson. You never can find 2 similar harley. Tamiya did the same. Mr T never made the same SRB. That is so hard to say that is a pure boxart or it was repaired...... |
That first picture isn't very logically laid out - left gearbox halves on the right of the picture, pairs not together ... if we rearrange it ... ... then I'm sure that the left gearbox halves 1 & 2 have been misnumbered - although we'd need to see the reverse angle to be sure (1 should have a large round sticky out bit on the box section right at the front, 2 should be flush). I can see why they've been numbered like that - but assuming the revese of the shafts/bearing holders goes from stacked O's on 1 to a figure 8 on 2 and stays that way for 3 doesn't stack up to me, it's a feature that doesn't have a corresponding one on the other half, whereas the rib on the bottom of the rollbar mount would have to come and go in direct opposition to the other, visible half. Making that "correction" ... Looking past that, I think it confirms "mk.1"/early and "mk.2"/later - but also shows a "mk.3" (/Super Champ?) , which I don't think I knew about before? |
The pictures I've used are some I took many years ago, not for Mk.-comparison, hence the un-logic sequence.
However I don't agree with the last swap you did of the left halves. It' does not make sense to to me that Tamiya had a reinforcement in the design, them removed it, only to take it back in again. I'll see if I can find pictures of the inside. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
