Is there a way using a multimeter to see, once a battery has been charged, how many amp hours it will produce, or do I just have to put it on a car and run it til dead?
If using a multimeter is possible what settings etc and formulae if required TIA Alan |
You will have to discharge, so you need two meters if you want to DIY, one for voltage and one for amps.
www.ebme.co.uk/...-batteries |
Cheers for the input WB
I’m gunna give one of these a try when they are back in stock, I know it don’t tell me potential mah but at least it will tell me if all cells are taking a charge to full capacity, which is a good indication I would assume. If I’m wrong on my understanding of this please put me right. |
iMAX B6 charger shows mAH in/out on charge/discharge
And with the B6 you can charge all type of batteries. I use it for my 1/1 car's batteries. I bought it with JR advices. No regrets. |
This is sounding like something I should look at then |
Yep, I too love my B6 style charger
Keeps track of mAh in and out, very nice, not like the old days where my " really good " Astro Flight charger had an analog amp meter and a clockwork timer But battery maths have not changed, amps out for a given time period equals capacity at a given voltage. That last part is even more critical now with lipo batteries because if you go too far......game over... To be completely honest I have not really studied lipo theory other than to understand what I need to know to work with them. With the capacities available in a standard RC car pack size now, I more worry that I will get board with it before the battery quits I my previous life as an aircraft engineer ni-cads and lead acid are a very well know subject, charging , dis-charging, cell levels, cell blocking, all fairly important when you are dealing with ni-cad pack that cost more than $10,000 But a basic capacity test is still the same, applying a known load and timing the output until the voltage drops below the accepted level....not to zero. With big ni-cads we would block them out when the cell dropped below 1 volt, that is the actual working voltage of a ni-cad under load, so yes boys our old 6 cell 7.2 volt packs are really 6 volt packs ....but I digress....... So if I apply a constant 1 amp load to my old 1200mAh pack it should go for 1.2 hours before it drops below 6 volts ( 1200mAh does sound much bigger then 1.2 Ah doesn't it Ni-cad chemistry is very good at giving off its capacity in a big hurry, shorting out a big battery could be fatal So a bit long winded as usual but its my 2 cents worth, perhaps it might be of some use...... As for a meter to do it, just use the B6 discharge function it is simple and it works.... From somewhere out in the wilds of central Ontario.
Last edit: by oldwilly.
