Futaba S148 8 years 7 months ago #49196
  • Al
  • Al's Avatar Topic Author
  • Hog Heaven
  • Hog Heaven
Hi, advice / help please.
So this servo came on a chassis I picked up.
The main servo horn needed replacing so I ordered spares and fixed that.
When I’ve plugged it all in, it would only turn in one direction. So I took the top off and the small spindle just keeps spinning.
Is this thing just junk or have I missed something.
TIA,
Al
Futaba S148 8 years 7 months ago #49201
All the gears need to be installed so that the limiter can work, If the limiter is in the wrong position that could explain why it will only turn one way. Try and centre the limiter before installing the gears (while not connected) and if that sorts you out :)
Futaba S148 8 years 7 months ago #49202
  • Al
  • Hog Heaven
  • Hog Heaven
Cheers Andy.
I did try that, but as soon as I switch the power on the motor just starts running.
Thanks for replaying.
I suspect it’s junk.
Futaba S148 8 years 7 months ago #49212
Even if you can't fix it, I'd keep it - you never know when you'll need to modify a servo for constant rotation, need a dummy servo, or need a lead/plug - better to use that than kill a perfectly servicable one :)
Futaba S148 8 years 7 months ago #49213
  • Al
  • Hog Heaven
  • Hog Heaven
Cheers Jonny, no worries about it going anywhere near the bin.
The gears I bought may come in handy at some point. But for now it will be good for just holding the steering in place on one of my projects.
Thanks .
Futaba S148 8 years 7 months ago #49214
  • Al
  • Hog Heaven
  • Hog Heaven
On the plus side, my original radio gear which is over 30 years old, just needed a clean up of the battery terminals in the controller and it’s working fine.
Futaba S148 8 years 7 months ago #49215
Nice radio Al.
Futaba S148 8 years 7 months ago #49218
  • Al
  • Hog Heaven
  • Hog Heaven
Cheers mate.
As a kid I’d been borrowing my dads M Series until I bought this.
Last edit: by Al.
Futaba S148 8 years 7 months ago #49219
Looks like a guetto blaster.
I never seen this radio.
Futaba S148 8 years 7 months ago #49220
  • Al
  • Hog Heaven
  • Hog Heaven
Great comment Flo, well that’s the 80’s for you.
Time to create page: 0.129 seconds
