QD remote replacement antenna test 8 years 1 month ago #51984
So here are the result of todays test. From left to right, original QD, 4.3 x 440mm replacement, 5mmx290mm flexible.
Antenna were sourced of ebay.
Original and replacement
Flexible
Range test, original Tamiya fully extended, remote held at approx 1m height - distance approx 50m
Replacement 440mm - dist. approx 50m
Flexible 290mm - dist. approx. 30m
Cost:
Replacement 440mm about 4€
Flexible 290mm about 5,50€
Really liked the flexible antenna even if range is less as with original but due to the size of the car and taking into account that its for kids. :y:
The following user(s) Liked this: caprinut, Jonny Retro, oldwilly, stingray-63
QD remote replacement antenna test 8 years 1 month ago #51988
Top work :y:
QD remote replacement antenna test 8 years 1 month ago #51989
Wonder if the flexibel one will work on lets say a Sanwa Dash 2 transmitter..?
Flexible should be better for tansporting and handling etc :y:
Time to create page: 0.193 seconds
