on/off switch 7 years 5 months ago #55432
  • nz
  • nz's Avatar Topic Author
  • Being nuts is NEAT!
I bought a car and it has no on/off switch!
Can I buy this and will it work in a Tamiya?
www.ebay.co.uk/...0005.m1851
Thanks
on/off switch 7 years 5 months ago #55433
Yes it works. But the switch is not necessary
on/off switch 7 years 5 months ago #55434
I leave always the switch on on position or remove it on all my rc.
on/off switch 7 years 5 months ago #55435
  • nz
How do you turn off the car? unplug battery?
on/off switch 7 years 5 months ago #55436
Yes only unplug the battery. That avoid a fail source.
on/off switch 7 years 5 months ago #55437
Note that if you are using a mechanical speed controller the only thing the switch will do is shut off power to the receiver. If the throttle servo gets bumped or moved somehow, you still have power to the motor and the car will take off with no control. Best to disconnect the battery. If you using an electronic speed control, then the switch shuts off everything.
on/off switch 7 years 5 months ago #55438
I always disconnect my battery esc or msc. Same if the switch is on the esc, I keep it always on on position. I already had matters with oxyded switches .
Time to create page: 0.118 seconds
