RZ superstock motor 7 years 1 month ago #56694
  • Girox
  • Girox's Avatar Topic Author
  • Anytime Baby!
  • Anytime Baby!
Hello people.
Does anybody know whether the rz motor will fit in a vintage Supershot?
Thanks
Matt
RZ superstock motor 7 years 1 month ago #56695
I haven't tried but I'm pretty sure the motor will fit physically.
If the gearbox can handle the torque/power is another matter... :)
RZ superstock motor 7 years 1 month ago #56696
I'd also look at the gearing - if it's too tall you risk the motor overheating & pulling too much current through the wiring and speed control.
I'd start with the 13T pinion & work from there - if the car goes "NNNNNNNNNEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!!!!!!!!!!!!1111111111111111" & passes you at like 2km/h, you can try the next pinion size up (15T).
RZ superstock motor 7 years 1 month ago #56697
  • Girox
  • Anytime Baby!
  • Anytime Baby!
To Larbut & Jonny,
Thanks you for the advice. The gearbox I kinda figured in fact, the current no.
I tried to bid on two technigold engines on eBay until the end but I let them go because they both went over my budget. One ended at 95€ the other at 125€! Next time maybe. If I get the rz il start with a 13t pinion gear and see. Thanks a lot!
Cheers
Matt
Time to create page: 0.165 seconds
