Vintage Sand Scorcher ball joint diameter 7 years 1 month ago #56867
Can anyone confirm the diameter of the original brass ball joint on the 1979 version of the SS please? I'm trying to buy replacement ball links and adjuster rods but the smallest I can find from tamiya are 4mm.
Vintage Sand Scorcher ball joint diameter 7 years 1 month ago #56869
They are black 3mm joints. Look for grasshopper direction joints
Vintage Sand Scorcher ball joint diameter 7 years 1 month ago #56870
Thank you for the quick reply. Does it matter if it’s Grasshopper or Grasshopper ll?
Vintage Sand Scorcher ball joint diameter 7 years 1 month ago #56871
No no matter. On the grass they are white but identical to the black ones.
The following user(s) Liked this: carpezant
Vintage Sand Scorcher ball joint diameter 7 years 1 month ago #56872
Thanks for the help with this - Phil
Vintage Sand Scorcher ball joint diameter 7 years 1 month ago #56873
You're welcome :)
Time to create page: 0.118 seconds
