Madcap Parts Sourcing Help Needed 6 years 11 months ago #57258
I am new to RC cars and this is the first part that I have needed to source! My Grandkids managed to smash my Manta Ray into the side of my Madcap and break the 3 pin ceramic resistor Part No: 17265011 or 7265011 and break one of the plastic mounting posts off. I can glue the post back on but I will need a replacement resistor. Can someone advise me where I can get a replacement? I am in the UK.
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57261
You can find a basic but efficient esc for cheaper. Look at wish or aliexpress. And esc are better than the classic msc.
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57262
If I went over to ESC control does it still operate with my vintage 27MHZ controllers as I only own vintage equipment?
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57263
Yesss my madcap has an esc with a period acoms mk5 techniplus.
Your 27mhz radio should have a bec system. No matter. ;)
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57264
Thanks that's great but can you explain to me (a novice!) what a bec system is?
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57265
Yes the bec system is battery eliminator system . I think.... it avoids the use of a receptor alimentation clip. The main aq is used for the motor and receptor.
That should be easier if you could post a picture of your madcap ;)
Last edit: by stingray-63.
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57270
Here you go:
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57271
Nice! You can put an esc easily.
You have the same radio setup as mine.
You can have one for less than 10€.
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57275
If you want to stick with a Tamiya unit I'd recommend the TBLE-02S which you should be able to find for around 15 GBP, or the Mtroniks AutoSport Tuned 20 for a few more quid, but has the advantage of being (mostly) waterproof.
If you want to go for a replacement resistor, I doubt if any suitable new ones are available ... I'm sure you could find a new, old stock complete Mechanical Speed Controller - but for more than a basic Tamiya ESC would cost :blink: A 2nd hand one may be difficult to buy on its own, I (along with most people I guess) threw away loads of them as the percieved value was practically zero :(
Further thoughts ... 2.4 Ghz radio sets are great for kids as there's no long antenna to bend (my youngest neice broke 4 in 20 minutes once :cry:)
... Don't let kids near your toys, get them something slow for themselves where they can learn throttle control ... New Grasshopper kits (with a tiddly 380 motor) are really cheap at the moment, like 60 GBP posted. Another alternative is a higher turn (higher torque, but much lower speed) motor, a 45T or 50T motor will slow things right down, 35T will take the edge off without being too tedious.
Last edit: by Jonny Retro. Reason: missed unit
Madcap Parts Sourcing Help Needed 6 years 11 months ago #57277
Thanks for all your advice everyone I will digest and decide on the way ahead.
Time to create page: 0.140 seconds
