Hi-Cap Dampers 6 years 11 months ago #57665
  • blakbird
  • Impressive Numbers
Does anyone know if the newly released 47358 Hi-Cap dampers for the Top Force re-re will fit the Vanquish? It looks like all 4 may be the same length so I fear they might not work on the front.
Hi-Cap Dampers 6 years 11 months ago #57668
I have egress hi caps on mine as you need the mini fronts.
It does really need a different shock tower though. I designed one that gives more shock length for more travel and lowers the car about 10mm so the chassis now bottoms out before the shocks. I then flipped the rear shock mounts brackets to lower the rear.
Time to create page: 0.098 seconds
