TA02SW Diff issues. 6 years 9 months ago #58002
I have a mate that have the black Anneversary 934 RSR TA02SW.
Or rather it's his son that owns that car.
Problem is the splines into the balldiff are now gone, not on the outdrive cups, which I belive are the hardened type.
Are there any hardned diff sides available for this, from Tamiya or aftermarket?
Or is he simply have to replace the worn parts for stock items?
Don't know which motor they are using, but it's powerful.
His dad used to race on-road cars, so when he says powerful, I belive he means exacly that...
TA02SW Diff issues. 6 years 9 months ago #58009
You can use the top force evo sides.
TA02SW Diff issues. 6 years 9 months ago #58010
Flo those are even softer (aluminium)
Trick is to keep the outdrives in place if there is to much play and power on them thew will strip the splines. Either some glue or the o-rings trick
Or switch to gear diffs those are more stable than the balldiffs under pressure. (Wider spines)
TA02SW Diff issues. 6 years 9 months ago #58011
Thank you both :y:
Ill report back to him :)
Time to create page: 0.676 seconds
