Hi guys,
I have a question to avoid to toast my old sanwa gc3300 rx I puted on my mountaineer. I puted a period esc a futaba mc112 in place of a msc. The gc hasn't a bec system. So I used a 4cells clip. But the system works without the clip. Like if the esc gives power to the receiver. Is it dangerous for the receiver? Should I keep the cells clip or not? Is there a risk to toast the receiver with the esc? I took a 10 minutes run without matter nor burning smell. Thanks for your advices. Flo |
What's the output on the +ve (& -ve) from the ESC? A multimeter ought to be part of everyone's tool kit, even a 5 EUR analogue model. I don't believe there is a standard as such, but the Tamiya TEU101BK outputs whatever the drive battery is outputting (so up to 11v+ for a freshly charged NiMH pack I wouldn't count on being safe, you'll think it's fine right up until the magic smoke escapes
Thanks Jonny. I will control all that.
please take note the old sanwa are wired different too the servo wire
from the futaba |
Last edit: by spannerman3.
hi yes u can use a new esc on the 2200 receiver so i guessing u can do this all so to the 3300
have a look if i was u i would be getting a broken servo from the 3300 then take the wire off the servo then buy a female futaba plug then put the plug onto the end so the the esc will into it |
sorry if your thinking why is there only one plug in the receiver
1 for the servo and the esc is hard wired in and if anyone got a spare 2200 receiver bottom please email cuz i had to brake it to get it off PLEASE one of the screws were rust bad works great |
Thanks spannerman. Modern connectors fit on the 3300. Naturally with the + on the right side.
Sorry I sold a 2200 last year. |
hi stingray-63 would u know the question
the Turnigy 1000mAh 2S 30C 7.4v Lipo Pack Battery XT60 JST-XH i have a battery charger iMAX B6 what do u charge this at lipo 7.4 2c 500mah that right? balance charge i just want to make sure |
No lipo charging is generally 1c. So, your stick is 1000mAh 2S you have to trim the b6 on 2S at 1000mAh (1A) and plug the balancing wire.
