Car cuts out + jittery servos 6 years 5 months ago #59987
Hi all
New to the site so hello everyone 👋
I have a original grasshopper 2 and I have been rebuilding and hopping up some parts.
Now I have a problem, for a few years (I know, part timer 😂) the car runs okay for a few minutes then either shuts of or the steering and throttle become very erratic. Also the servos crackle/pop.
So in the last few days I have got a new nimh battery, tried a new old stock msc, and got a new esc but the problem still persists.
The Msc was a original Tamiya with new resistor, and the new esc is a mtroniks auto sort 20.
The motor is a hpi Saturn 27t brushed.
Radio acoms techniplus with ar-17 servo/s and at-2/27 bec receiver.
Help please!
Thank you
Car cuts out + jittery servos 6 years 5 months ago #59989
Could be lots of things, but most likely a bad servo. If it has an internal short it could be overloading the BEC causing the whole thing to shut down.
Car cuts out + jittery servos 6 years 5 months ago #59990
Hi Blakbird!
All the acoms gear came together as a set, is it likely this could happen?
To further detail, the car will resume operation again after a few seconds but for the most won’t be under my control.
If I have the car up off it’s wheels the throttle is mostly fine with maybe a few quick blips, however the steering servo can crackle. (This with new esc) however I can have full control most of the time.
I thought replacing the msc might help but not quite.
I was leaning towards the receiver, and have spoke to a hobby shop who suspect this also.
Unfortunately my local shop closed a few years ago and none very near now.
Thanks
Car cuts out + jittery servos 6 years 5 months ago #59991
Is the problem from a distance? Near 3 4 meters? The matter can be from receiver or a servo. If your antenna has been cut or a dry weld
Car cuts out + jittery servos 6 years 5 months ago #59994
Hi stingray
Yeah probably 3-4 metres after a few minutes use.
Tx still original acoms screw in type antenna no damage to it at all.
Have two as-17 servos, if using esc steering goes mad, and if using both with msc both go mad.
It’s driving me mad! 🤪
Car cuts out + jittery servos 6 years 5 months ago #59996
In my mind, 3 4 meters, it should be the rx antenna wire too short or simply a crystal mater. Try another crystal pair. And measure the antenna length. For the 27mhz it should be 25 or 50 cm lenght ( longer is better)
Car cuts out + jittery servos 6 years 5 months ago #59997
And don't roll the rx antenna wire. And insukate it from motor and other wires.
Car cuts out + jittery servos 6 years 5 months ago #60003
All the above are good suggestions - but another thing is that 27mhz radio gear has always been prone to interference. Road vehicle spark ignitions, Cb, power lines, radio/tv masts etc etc all caused issues back in the day, but in comparision the air now is super saturated with RF signals both in & outside the home.
One test you could try is seeing how it behaves in the most remote place you can find (difficult under present circumstances). There's a reason why people paid a premium for 40mhz sets BITD, and everyone uses 2.4ghz sets for any "serious" use now.
Car cuts out + jittery servos 6 years 5 months ago #60010
Hi stingray
I have measured the tx antenna and it’s nearly 50cm and no damage or kinks that I can see.
I have another set of crystals so will try them, but with electronics all on bench I still get servo jitter with both sets of crystals I have.
Thanks for the advice thus far!!
Car cuts out + jittery servos 6 years 5 months ago #60011
Hi Jonny Retro
I did wonder about wether to update my radio gear to a 2.4ghz set. I have been offered a Carson reflex stick pro 3.1 2ch plus receiver for £30 so that might be the way to go!
After that all I’d have left to change is the servo if it persists! 😩
Time to create page: 0.509 seconds
