Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63192
Hi. I purchased the Avante Carbon Fibre chassis kit 53038 but the Vanquish Front Body Mount in step 1 is missing. Does any one know the part number? I have checked the Vanquish 58076 but the front body mount is different.Jeff
Last edit: by larbut. Reason: Removed doc file and inserted the image inside it.
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63198
Try on ebay
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63203
Isn't it the Avante body mount BB1? It's in the B screw bag.
If it's the same as the one from the Top Force, I should have a few but no clue where they are...
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63205
Hello. The body post does not thread into plastic it mounts between the two pieces of the front mount. Did my picture come through properly?
Jeff
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63206
The attachment appears to be a .doc file which I am inclined to not open...
Perhaps you could insert a file with an image format.
Edit - yeah okay, not the same one...
Source
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63282
Thank you for looking, does anyone else have an idea what the part is? I still have have had no luck on ebay or through searches on the net.
Jeff
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63294
I can see the alloy mount that you are searching for but unfortunately also cannot find any extra information for it, I doubt it has it's own part number. I can only suggest having one made, Do you have access too or a person who has access too a lathe? If you gather all the required measurements it will be an easy part to machine.
Cheers Andy.
Last edit: by AndyAus.
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63295
Thank you for looking. My brother has a milling machine so I may try that.
Jeff
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63297
Jeff
I hope he has a lathe too, A mill is good for flat surfaces ;)
Avante 53038 and Vanquish Body Mount in step 1 5 years 10 months ago #63304
I don't understand where is the matter. Isn't it the same as the egress one? The chassis is the same as the egress on the avante 2001 in size.
Time to create page: 0.120 seconds
