Im looking at buying a new M-05 rc car and want to run a mini body on it. My question is , is the wheelbase adjustable? I've been looking at the information in the DataBase and the different M-05 models seem to have different wheelbase sizes.
Last edit: by DonsF1.
Not infinitely adjustable, but all the M-05 based kits can be built as "S" (210mm) "M" (225mm) or "L" (239mm) wheelbase (distance between wheel centres on each side).
IIRC they're all 165mm wide, & a basic "original" Mini saloon body will fit on the "S" wheelbase.
The following user(s) Liked this: DonsF1
What is interesting with the m05, is that you don't need more parts to modify the wheelbase. You just have to play with rear train parts.
turn the arms around and add spacers between shock and shock tower
i think i used a saw to add more length... i don't know anymore exactly I have only some pictures but you can use google, there is allot of info on stretching the m05 edit, i made the car RWD that was it... maby dont know anymore i am confused by the hiluxes Attachments:
The following user(s) Liked this: stingray-63, DonsF1
Last edit: by poebe.
