Hi, finally rebuilt my rere tamiya hotshot. On the first run both the esc and motor got hot to the point where I couldn’t keep my finger on it for more than a second. I’m running a sports tuned motor with a teu-105bk esc, 15t pinion, the stock spur gear (56 teeth), stock tires and 3600mh batteries. Should I worry about the heat or is the setup fine.
ps both motor and esc cooled down pretty fast (5mins) and they are cold again.
Last edit: by Aras.
IDK what your tolerance for heat is, but if the ESC didn't "thermal" (temporarily shut itself down due to heat to protect itself) you're probably ok - but three seconds is usually considered the appropriate test (around 70 degrees C).
Driving style, location & surface will also have a big effect on heat - on & off the throttle on a small grassed back yard will put much more strain on the electrics than say a wider open space on a looser surface. You could consider lower gearing (more acceleration, less top speed), I'd also check that nothing is binding (pinion gear spacing, driveshafts/bearing etc). You could buy a cheap IR thermometer if you are concerned. TBH I used to use excessively handwound motors with tall gearing & extra cells in inappropriate cars on stock MSCs BITD, I considered mild bluing of parts as completely normal, & anything less than a fire was fine |
