HiWill the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet if I purchase the Hotshot E part triangle hub? My concern was the axle maybe a different length.Thank you in advance.
Yes it should.
Thanks for reply.
Another member has told me, whilst they would fit the axle is too long. Alternative is to purchase Nova wheels / adapter and fit the Hotshot tyres to them. |
Just use spacers between the wheel and the wheelnut to take up the extran length of the axle.
4mm washers or a piece of 6x4mm tube should work. Also a M5 nut can be used as a spacer.
You can use a 850 bearing to
