RX540Vz replacement rotor 4 years 2 months ago #72471
Hello, does anyone know if Tamiya ever released a spare rotor for the RX540Vz motor as they did for the technipower (rotor 5227) and technituned (rotor 5231) motors? If so, do you know the part number.
Jeff
RX540Vz replacement rotor 4 years 2 months ago #72476
I have got a sd for sale but the vz ... dont know!
good question. isn't that the same rotor?
www.ebay.nl/itm/334348010521
RX540Vz replacement rotor 4 years 2 months ago #72477
The TB database lists the Technituned as a 27 single & the Technigold as a 21 single, so no, not the same rotor.
I looked in my Tamiya catalogues, 1986 shows the Technituned, Techituned rotor, Technipower motor, Technipower brush set, and the Technipower rotor - but no Technigold motor or anything for it.
1987  and 1988 show the Technigold motor only.
1989 shows the Technigold motor, and a brush set for it - part 50312
1990 moves away from the picture grid format, but the Technigold motor & brushes are listed.
1991, 92, 93, ditto
1994, nothing "Techni" is mentioned at all.
I don't have anything like a full perm of the RC Guide Books, but I do have one from 1987 (with the Bigwig on the front) - that only has the Technigold motor.
I can't say definitively that Tamiya never released a Technigold rotor, but I would expect it to have been documented, so it's probably a no :(
The following user(s) Liked this: stingray-63, poebe
RX540Vz replacement rotor 4 years 2 months ago #72479
I never saw a vz technigold rotor in spare. But I know that graupner sold it. Maybe a source. And from mabuchi 0 spares available. Like if they never built this motor.
RX540Vz replacement rotor 4 years 2 months ago #72480
Maybe find another rotor similar from yokomo
RX540Vz replacement rotor 4 years 2 months ago #72481
Thank you for your answer. The rotor shown is a 27 turn the RX540Vz is a 21 turn.
RX540Vz replacement rotor 4 years 2 months ago #72482
Thank you for all the information. I do find it odd they never released a spare rotor for the RX540Vz.
Jeff
RX540Vz replacement rotor 4 years 2 months ago #72483
the rx540sd is number 5231
there is also this one 5227
do we miss 5228 5229 5230?
This rotor can be used in the technipower and technituned motor.
wat are the differences between those 2?
interesting treath!
50225 RX540SD TECHNIPOWER
Type:Brushed
Timing Adjustable
Maintenance Rebuildable
Turns: 23x1Wire:
Normal voltage: 6 - 8,4 V
Torque: 315 g/cm at best efficiency and 7,2V
RPM: 20300 rpm at best efficiency and 7,2V
Current: 11,2 Amp
50230 RX540SD TECHNITUNED
Type: Brushed
Timing Adjustable
Turns: 27x1Wire:
Torque: 290 g/cm at best efficiency and 7,2V
RPM: 17200 rpm at best efficiency and 7,2V
Current: 11,2 AmpKV
Last edit: by poebe.
RX540Vz replacement rotor 4 years 2 months ago #72484
Same on the rz. They have same cage / stator.
RX540Vz replacement rotor 4 years 2 months ago #72485
the number of turns is not the same...
Technipower Rotor 23turns and technituned rotor 27 turns
i have a 5331 technituned rotor here. i will check later if it is possible to count the turns on the rotor
Time to create page: 0.126 seconds
